THIRD PARTY INSPECTOR
3
hi
in the ASME Code .is the third party inspector mandatory?
if the answer is yes.PLZ tell me the address.
THANX
RE: THIRD PARTY INSPECTOR
If the third party inspector you refer to, is one appointed by the customer, to protect their interests, the answer is no, its not a Code requirement.
If you are referring to NBIC Pressure Vessels, the answer is yes. You are required to work with the Authorized Inspector prior to and after any work.
What code?  There are many standards, some are known as codes.
What jurisdiction?  If in the US, then the Federal Register may identify a standard or code as a legal requirement.
What application? Is this for a governmental entity, private entity, self-insured, etc.
Most who post on this web site are engineers, few of us are lawyers.  The term mandatory sounds rather legal, doesn't it?
Slow down a bit. Are we talking ASME BPV Code or ASME B31 Piping Code???
I concur with JLSeagull. First of all all pressure equipment fabrication and installation may or may not be regulated by a local government. That regulation will tell you what legal and safety requirements are (eg. what code of construction is aceptable, vessel stamping requirements). That regulation may also tell you what the inspection requirements are (eg. third party invovement/certification etc)
Taking purely the codes:
For ASME BPV involvement of Authorized Inspector in fabrication and certification of the vessel/boiler is a requirement for ASME stamped vessels/boilers.
For ASME B31.3 Piping, the involvement of Owner Inspector in pipping fabrication is mandatory.
For ASME B31.1 BEP PP stamped, involvement of Authorized Inspector in piping fabrication and certification is mandatory.
Please read the codes.
Putting Human Factor Back in Engineering
if ASME BPV Code is my mean.
if the involvement of Authorized Inspector in fabrication is mandatory what`s the address of it in Code?
thanx.
MicroEng:
Read ALL of UG-117 it tells you how to obtain an ASME Cert and it also contains the requirment for an agreement with an AIA. You CANNOT build and stamp an ASME vessel without an Authorized Inspector involved.
If you don't have a Code book buy one, if you have a Code book look in the index its a good place to start.
MicroEng,
also look at UG-90-->96, these paragraphs clearly stipulate the AI's role
RLS
If your in a Code State, you should be able to contact the Department of Compliance.
You may also go to http://www.authorizedinspector.com/ to find one if its aplicable.
thanx all .
i get my answer ...more of answer .
best regard
