LISP Routine to place a Northing and Easting at the end of a leader
My first post!
I found this code on this forum posted by IFRs (Petroleum)and made a couple changes based on what I was able to figure on my own.
(DEFUN C:PTT (/ osm p1 x y s p2) ; ID a point, place coordinates text
 (graphscr)
 (setq osm (getvar "osmode"))
 (command "osmode" 53)
 (setq p1 (getpoint "\nSNAP to point to be ID'd: ")
        x (car p1)
        y (cadr p1)
        s (strcat "N:" (rtos y)"'" " E:" (rtos x)"'" )
 (command "osmode" 0)
 (setq p2 (getpoint p1 "\nPick point for end of Leader: "))
 (COMMAND "DIM1" "LE" p1 p2 "" s)
 (command "osmode" osm)
 (princ)
I would like to see the N coordinate on one line and the E coordinate below it in the graphic. Can someone show me how to accomplish this? Thanks in advance.
RE: LISP Routine to place a Northing and Easting at the end of a leader
Add a "\P" to break a line.  ie try  (strcat "N:" (rtos y)"'\P" " E:" (rtos x)"'" )
IFRs:
First of all: Thanks for posting the original code.
I still can't get the break to work though. I wind up with a "P" between my northing and easting in the graphic.
A reply from the autodesk forum works good!
Your code with the minor modifications:
(graphscr)
x (car p1)
y (cadr p1)
s (strcat "N:" (rtos y) "'" "\n" "E:" (rtos x) "'")
(princ)
Again...Thanks for everything!
I knew it was a slash something!  Good work!
