My first plc program
I have connected everything to just switch one light.  I have programmed it.  I am using Moeller PS4-141-MM1, PLC.  When I try to transfer the program, there is a complaint about an already existing program  (the last programme was for a different task).  There is also a complaint about the devices.  The software Sucosoft Version 5 seems to recognise only PS4-200, 300 and 400.  How do I override the old program?  How do I add another device to connect to? Help!
RE: My first plc program
Thought there should be an option to erase (blank check?) the module 1st...
Or overwrite the without asking..
