Steel with yield strength in the range of 75,000 to 85,000 PSI
Hi everyone,
Can anyone please recommend a steel that is reasonably easy to machine and work with, & that has a yield strength in the range of at least 75,000 to 85,000 PSI ? I would rather not get into heat treating in order to achieve the desired yield strength if possible.
The small part would likely be made from flat plate stock, and could be made from a block 2.25" wide X 2" long X 1" high.
Does anyone know of a reliable web site or metal supply site that will give the price for the steel in flat and/or round stock, and then give the specs for the steel as sold, such as yield strength, machinability rating, general technical data on the steel etc. ?
I would like to be able to specify something the machinist can readily obtain, and obtain at reasonable cost. It seems the same grade of steel can come in different conditions or be processed in different ways that effect yield strength, so I need to be able to specify those conditions / processes and also know that the steel is available as flat or round stock as required.
www.matweb.com has much technical data, but it does not really help me narrow things down such as, will the material be hard to get, what will it cost, does it come in flat or round stock as required, & also in the condition to meet the required yield strength, etc..
I would like to be able to specify the exact grade and conditions so that I can rely on the yield strength being met, and know that the steel is available in flat or round stock as required.
Any recommendations or web sites you could direct me to would be appreciated.
John
John
RE: Steel with yield strength in the range of 75,000 to 85,000 PSI
h
Thanks for your reply metengr, I will check out the site you gave.
So far, it looks like I might use 1080 as rolled, with a yield of 85,000 PSI or 4140 normalized with a yield of 95,000 PSI.
4140 normalized has a machining rating of 65 % Based on AISI 1212 as 100% machinability. I'm not sure how the machinability 1080 compares.
I may find better options after looking at the site you gave.
Thanks again,
John
You can use ASTM A4140/4130 HRc 18-22. Most commercially availbable steels would categorize this as L80, i.e. 80 ksi yield, the lower end of your requirement.
If you need something a little harder, then P110 would be ASTM A4140/4130 HRc 28-32. This comes in at 110 ksi yield which is to the top side of your requirement.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
SAE 4130 condition F Sy = 100 ksi
or
ETG100 of Steeltec Switzerland.
Both are high strength machining grades.
Good luck.
Best regards,
ct
For high strength, good machinibilty we something use 17-4PH or equivalent.
Particularly in doing torsional vibrations, you'd be surprised on the number of errors in converting I have witnessed, some with rather costly results too.
But I keep dreaming of a better world witn only one system of units (although that seems pretty trivial these days)
