Vacuum Collapse of Spiral-Wire Reinforced Hose
I am having a tough time applying ring stiffener calaculations to my Rubber "vessels" that are Spiral-Wire reinforced. The wire I am using is hard drawn and has high tensile and yield values, but the EI=P*D^3*L/24 formula for collapsing pressure doesn't change for the higher value because it is E dependent. The E for the wire is the same as plain steel. Does anybody have any insight on this?
RE: Vacuum Collapse of Spiral-Wire Reinforced Hose
jt
