SA-212-B Stress Value
Can anyone tell me the stress value for SA-212-B at 500 degrees F? I know that SA-212-B was discontinued in '62.
RE: SA-212-B Stress Value
SA212-B had a basic allowable stress of 17,500 psi up to 650° (based on the 1962 and '65 codes). It was a 70 ksi UTS steel replaced by the SA515-70 and SA516-70 steels around 1967.
jt
"Can anyone tell me the stress value for SA-212-B at 500 degrees F? I know that SA-212-B was discontinued in '62."
What is it that you are asking for? Do you want the yield stress for the material? Do you want the ultimate tensile stress for the material? Do you want the Code maximum allowable stress for the material? There is a different value for each of these for each Code. What are you going to design with this data? Piping, Pressure vessel, tank.....?
jt
In the 1949 edition of VIII, S for SA212-B is listed at 14,000 up to 650°F.
jt
