Concrete Flow Deflector
Does anyone know an approximate cost for concrete flow deflectors?
RE: Concrete Flow Deflector
a little more information might help...
the deflectors are for a curb inlet with a 10' throat
I am not clear on what you are looking for.  Is this:
A flume to direct runoff toward, or away from, the throat?
A weir/baffle on the bottom of the inlet box?
An energy dissipator at the end of the pipe?
In any event, first check a local precast supplier.  If this is a standard product (or even a fairly common custom one), they can almost certainly offer a product at an attractive final cost versus cast-in-place.
Engineering is the practice of the art of science - Steve
Or is it a device to deflect the flow of unset concrete?
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
how about a concrete valley gutter?
