finite elements model that reflect the reality
Hi every body,
I’m a new in finite elements analysis method and I have some questions:
- What are the best procedures that must be used to obtain a finite elements model that reflect the reality?
- How we can trust to finite elements softwares?
- Does it exist standards and specifications to guide engineers to do the best mesh that can insure the more accurate results?
RE: finite elements model that reflect the reality
2) gold i trust, but FEMs ... don't turn your back on them or they'll bite you. we don't "trust" the FEA software, we do a bunch of test cases to build confidence the it is lying (by commission or ommission).
3) MSC has published some good QA standards that will detect real trouble with your models (sorry, i don't have a link), but it's up to you to understand the reality of your problem and to decide whether your FEA is following this.
SofieneFEA, you may want to look at NAFEMS (www.nafems.org). They sell standards and benchmarks and fund a number of studies of different software packages.
Some of the information that you want to read about is mesh sensitivity analyses (seeing if a refinement in your mesh produces a significant change to your results), but above all, experience will help a great deal. Compare some simple results to textbook questions and hand calculations. Practice using different material models, element types, and boundary conditions.
Get inside the "black box" of your software
Understand how your software is calculating various aspects of your model and learn its limitations...they all have them. Most of them handle linear, static problems just fine and if that is all you are doing, your job is simple. More complicated analyses, make sure you understand the physics behind the analysis screen.
Garland
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
You also need to know something about the theory of finite elements. If you want an overview without too much math, consider the following books:
Finite Element Modeling for Stress Analysis by Cook
Building Better Products with Finite Element Analysis by Adams & Askenazi
To gain confidence in the software you’re using, run simple test cases and try to reproduce expected results. Most software comes with example problems, or better yet, devise simplified cases relevant to your problem. If you’re dealing with plates, get a book on plate theory, make a simple model of a square plate with uniform pressure, and see if you get the textbook solution. If not, don’t give up until you find out why. You'll learn a lot from this process.
Also, use the simplest possible model that adequately represents the behavior of the actual structure. It’s easy to make an overly complicated model, but it will be more difficult to de-bug. Try to get in the ball park with a simpler model, and add complexity only if necessary. And you can’t put too much faith in the answers if you don’t know the input data very accurately. You might have reliable material properties, but how well do you really know the loads? Seemingly small details can have big effects.
Besides NAFEMS, here are a few web sites that might be useful. The last one contains course notes for a college FEA class.
http://femci.gsfc.nasa.gov/index.html
http://hom
http:/
2. You can only trust your FEA model as much as you trust your assumptions. Experience is the only way to trust your assumptions.
3. FEA is not paint by numbers, and its downright dangerous to look at it that way. There are many different phenomenon to simulate and they all can require that you change the rules as you go. That said, there are general guidlines to keep in mind as outlined by countless textbooks and users manuals.
The bible of general FEA (numerically speaking): Finite Element Procedures, Prentice Hall, 1996; Klaus-Jürgen Bathe.
CJ
Last bit first. I don't know the exact proportions here, but my guess is that most FE analysis' fail due to poor understanding of the boundary conditions, loads, and mechanisms, rather than meshing errors as such. I'll include abuse of rigid elements as a boundary condition/mechanism problem.
Cheers
Greg Locock
This scatter is especially important if your test is a fatigue test. Even in the simple case of repeatedly applying one stress, the range between the 1st percentile and the 99th percentile part can be several orders of magnitude. As a specific example, the range in expected fatigue lives for C355-T6 cast aluminum is a factor of 1000. That is, your strongest casting might last 1000x as long as the weakest one.
Doug
Cheers
Greg Locock
