about the paint booth exhaust
How to decide the exhaust air flow for a paint booth hood? What kind of exhaust fan is typically used? The ASHRAE mentions the ACGIH. What's that?
RE: about the paint booth exhaust
Paint booth ventilation is such a common application that the problem is addressed by a number of Ventilation textbooks. I think the ASHAE manual does not go into it because it is not the core subject of air conditioning and refrigeration.
There are a number of points to watch with paint booths
1 - if the air velocity is too high the wet paint will start to run and disturb the finish
2 - the air must be filtered - otherwise dust will be attracted to the wet paint
3 - the exhaust will carry droplets of paint. This tends to build up on the inside of the ducts, and on the surface of the fan blades
4 - you cannot discharge paint into the atmosphere - so you have to make a plan to clean up the discharge. Often spray chambers are used to trap the paint droplets
5 - a small hood may work with a kitchen propeller fan, but for a larger volume you will need a centrifugal fan. The pressure drops involved will also dictate this. Talk to a fan Vendor for a recommendation
6 - it is important that the air distribution is as even as practical - to prevent fast moving streams developping in the painting space
OSHA regs protect the worker inside the booth; typically require some minimum velocity of 60-100 linear feet per minute, depending on application method.
EPA regs are to collect the paint overspray on the filters, filtration efficiency depending on the hazard & volume of paint applied. Minimum flow rates & changing filters is required when ΔP across filter reaches 1.5" water column (or similar). So, allow a deep plenum for high capacity bag filters to minimize changing.
OSHA & Fire Code may require internal sprinklers in both booth & plenum, plus approved booth lighting, for flammables.
http://www.chemcomfg.com/overspray.htm
Chapter 9 in DOD Handbook INDUSTRIAL VENTILATION:
http://www.wbdg.org/ccb/DOD/UFC/ufc_3_410_04n.pdf
Their "Industrial Ventilation" handbook has specific paint booth requirements and design parameters.
http://www.acgih.org/home.htm
B.E.
