Stormwater routing methods
Which stormwater detention pond routing method is the most accurate and where can I get some information on it........
RE: Stormwater routing methods
The storage-indication method (aka Modified Puls) is the most common method for level-pool routing.  You can find a detailed description in most H&H textbooks.  Google will find many references such as these:
http://www.engr.colostate.edu/~ramirez/ce_old/classes/ce422_ramirez/CE422_Web/Homework_8_00/Homework_8_00_Sln.htm
http://www.comet.ucar.edu/class/hydromet/09_Oct13_1999/docs/fiedler/oct99_routing/sld009.htm
SI routing is provided by many H&H programs such as HydroCAD
