Contour lines Visualization
A is a field output, B is another field output. As we know, the results for each can be displayed in a contour mode (visualization). Now I do not know how to display the contours line of the ratio A/B.
Thanks for help
Thanks for help
RE: Contour lines Visualization
is that right. But I could not know how i get AVERGAES of A and B throughout the model elements. Plese advice
corus
So the element output will give stress components at 8 nodes and pore pressure at 4 nodes. Hence i cannot creat field output pore pressure/ first stress componenet
Therefore I thought that I should get the the average value of pore pressure throughout the element (field output A) and the average value of the first stress componenet S11 throughout the element ( field output B) and then I beleive I can creat a new field output A/B.
Thank you
