Excel dates to Outlook
I'm new to VBA. Is there a way to insert dates into an Excel spreadsheet and have the dates and other info (names, etc) get inserted into a shared Outlook calendar?
Thanks.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
RE: Excel dates to Outlook
Check out the info at:
http://www.dicks-clicks.com/excel/olAutomating.htm
You will have to consider the binding of the Outlook commands as described on that site.
I used this info as a model to set up a worksheet macro, see code below, that creates an Outlook appointment based on the values in an Excel worksheet, which I placed in Excel cells named "date_default" and "subject".  Note my code always assigns the same time, but you could use named Excel references instead.  Very basic, but it works for me.
Good luck!
CODE
Sub SetAppt()
Dim olApp As Object
'    Dim olApp As Outlook.Application
Dim olApt As Object
Dim olNs As Object
' The following routine displays the calendar, opening OL if needed
    On Error Resume Next
    Set olApp = GetObject(, "Outlook.Application")
    If Err.Number = 429 Then
        Set olApp = CreateObject("Outlook.application")
    End If
    On Error GoTo 0
    Set olNs = olApp.GetNamespace("MAPI")
    If olApp.ActiveExplorer Is Nothing Then
        olApp.Explorers.Add _
            (olNs.GetDefaultFolder(9), 0).Activate
    Else
        Set olApp.ActiveExplorer.CurrentFolder = _
        olApp.ActiveExplorer.Display
    End If
'    Set olApp = New Outlook.Application
    Set olApt = olApp.CreateItem(olAppointmentItem)
'  Gather the values to use in the appointment
    usedate = Range("date_default").Value
    usesubject = Range("subject").Value
    With olApt
        .Start = usedate + TimeValue("9:00:00")
        .End = usedate + TimeValue("11:00:00")
        .Subject = usesubject
        .Location = usesubject & " location"
        .Body = "enter the text of your appointment here"
        .BusyStatus = olOutOfOffice
        .ReminderMinutesBeforeStart = 30
        .ReminderSet = True
        .Save
    End With
    olApt.Display
    Set olApt = Nothing
    Set olApp = Nothing
    Set olNs = Nothing
End Sub
bltseattle,
Thank you much! I will check it out.
Chris
AutoCAD 06
