Windows Apps using Matlab Compiler
I have already compiled m files to console applications using the Matlab compiler, but I'm wondering is there a way to compile m files to windows applications to get rid of the console screen?
RE: Windows Apps using Matlab Compiler
Edit the compiler options file before you compile
CODE
cd(prefdir)
edit compopts.bat
Add the following line for your compiler
LCC:
CODE
set LINKFLAGS=%LINKFLAGS% -subsystem windows
Microsoft Visual C/C++:
CODE
set LINKFLAGS=%LINKFLAGS% /SUBSYSTEM:WINDOWS /ENTRY:mainCRTStartup
Borland:
CODE
set LINKFLAGS=%LINKFLAGS% -aa
It's unbelievable, after a long time & no replies, I get a spot-on answer. Thanks a lot JockeK :)
One question though: How about if I what to use Dev C++ as the C ++ compiler. What is the command to the compiler for that?
Sorry, can't help you with that. I'm not an expert I just grabbed this from the Mathworks Support about 2 years ago and I can't find it there now.
"Subsystem" seems to be the keyword to search for in your compilers manual.
