Energy Conversion
Energy Conversion
What would be the best way to convert mechanical energy (i.e. human pedaling, cranking, etc.) into enough heat to boil water? Is there a way to go straight from mechaincal to heat, or would it work better to go to electricity and how?
RE: Energy Conversion
drive a dc generator that is connected electrically to a heating grid.
either way, it would likely take quite a while to "boil water". of course, how much water is needed to boil?
a solar water bag is better for warming water, but not quite boil.
good luck!
-pmover
TTFN
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
I remember a Dagwood comic strip from long ago. The door-to-door salesman comes around and says he is selling "hot rocks". The way they work is "You just rub them together to produce heat!" Closing line: "And if that doesn't work, by the time you're done, you'll be too tired to care."
Certainly it is possible. The question is how much water, and in what time.
The sustainable power output of a human is relatively well documented. If the power meters on excercise bikes are to be believed, I can sustain 100 watts pretty much indefinately, and peak near 300 watts for (very) short bursts.
As IRstuff said, do the math.
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int./JCI
But that spurred a thought.
Suppose you replace the damper on my exercise rider with an air cylinder and a check valve. That is to say, turn it into a vacuum pump...
If you turbine straight into a fixed volume of water that is well (perfectly) insulated, eventually that pot will boil - ie. as long as the heat doesn't get lost in the process.
I can't get past how fritzed out you are going to get when it takes 1hr to get your coffee fix in a morning - you are going to need to burn that energy off on a bike.
