28NiMo17 grade steel
I shall be thankful if I could get the chemical properties and heat treatment (i.e surface hardening or through hardening) for this alloy.i tried google search and other references but failed.
RE: 28NiMo17 grade steel
Is this a German spec material?  If so, it almost looks like 46XX or 48XX steel.
Yes it is a DIN specification. Alternate number is Nr 1.2747.
