??? input argument "n" is not defined
Dear Friends
I have written Function f(n) in Matlab m-file and when I am trying to call f(n) (earlier writng n=1) Matlab tells me: "???input argument "n" is not defined"
Could any body help me?
best regards
zbik
My function looks like this
function g=f(n)
g=n+1
RE: ??? input argument "n" is not defined
1 – for troubleshooting, type n before you execute the function.  See if Matlab comes back with 1 to doublecheck whether Matlab is seeing the correct value of n.
2 – I’m not sure if it makes a difference to y our question, but I thought an end statement is required at the end of a function.
Also I would try typing n=1 directly before the function and see if it works.  If it works there but doesn’t work within your program, then maybe you have a problem with variable scoping.  The variable n may have been defined in some function but is not available in the module that you are in now.  Look at the global statement and related matlab documention.
