basic dimensions in drawing tables
Hi
Another easy question
I have a basic dimension on a model. I want to add this into a hole table.
When I add the normal syntax, i.e. &d12 etc, the dimension is inserted into the appropriate cell, but the "basic dimension box" has disappeared.
I tried adding the @[...@] syntax but this doesn't do anything either.
Is the problem that the "basic dimension box is the cell?
Thanks in advance
Dave
Thanks in advance
Dave
RE: basic dimensions in drawing tables
I'm on old PROE 2001
-Hora
I wanted to leave the dimension as a basic, so if the model is interogated, this fact is obvious.
In the table, adding the conventional @[&d12@] doesn't work, but @[@[&d12@]@] does. It appears to be a "double negative" problem.
Cheers
Dave
