changing the angle of roof beams
I'm working on designing a Barrel roof, and I am using STAAD PRo to do so. when I have my girders vertical i need bigger beams then I do if I rotate my girders to the slope of the roof, I was expecting the opposite to be true, any insight on why this might be
RE: changing the angle of roof beams
can you elaborate more?
Lutfi
If you mean the principal axis orientation, I would expect the minor axis parallel to roof slope to be more efficient only if wind is the critical load.
