316 SS in high chloride water
Ok, my problem is a particular pump needs to be designed for water with chloride levels upwards of 3600 ppm and a PH of around 7.5. The pump manufacture wants to use 316 SS for the wetted parts and claims verbally that this will not corrode(atleast not too much for the design life). I am looking for any links or research someone might know of that can guarantee 316 SS for use in this concentration of chlorides. Max temp for this water is around 100 F but typically around 70 F
My concern is that everything I can find on 316 SS seems to be borderline for this chloride concentration with this PH.
M.
M.
RE: 316 SS in high chloride water
Are you pumping from a well? is there any oxygen? Will it run 24x7 or be shut down regularly?
You could get away with using 316 for the impellers if the bowls were made from a less corrosion resistant alloy (such as Ni-Resist) to provide galvanic protection. I would also make sure that there was carbon steel piping at hte outlet to provide a bit more protection.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
It has been suggested to Coal tar epoxy all the wetted parts but the impeller. You think if only the impeller was 316 SS and it was operated for all intensive purpose forever it will last 20-30 years?
M.
316 SS is unsuitable for this much chloride at these temperatures:
And you would need the exposed bowls to provide galvanic protection to the impellers. This means that they will be corroding. This limits their useful life.
Your system will be open and oxygenated.
20-30 years at those levels will take better metallurgy. Think of equipment suitable for seawater service.
If they are saying 3x concentration I would presume that you will see 5,000ppm before it is over.
Rust never sleeps
I just ran into this which mentions on page 3 that 316/317 is capable of handling up 5000 ppm chloride which, good guess Edstainless is the maximum expected but not operating. The customer is really leaning towards the 316 because of the price to upgrade these large pumps to a higher alloy, but if they fail...
The chart you have supplied Ken shows that 316 should handle what is 0.3% concentration chlorides at around 100 F(37.7 C for the chart). I am still searching and have a little time on this but all published info I can find seems to show that it is close but not beyond the capability of 316 SS for this service.
Although opinions on this page seem different, and although I felt weary about this system at first published information makes me feel like 316 will handle the chlorides.
Do you know of incidents where failure has occured for this type of service?
or any suggestion on a different material that wouldn't cost a arm and a leg to upgrade from 316 SS but could withstand the chlorides?
M.
M.
But, "chloride levels upwards of 3600 ppm" are clearly above, as will also be chloride levels if any drying during shutdowns.
Ken
1. Super duplex throughout with a PREN >40
or
2. NiAl Bronze, C95800 with Monel k500 gizzards
Steve Jones
http://www.pdo.co.om/pdo/
Don't fall for 316 or 317. At todays metal prices 2205 should be a better deal.
NAB C95800 would be a very good choice also.
If this is a single stage then a lined (not coated) housing is a good option.
Shaft and seals need to be high alloy since at shutdown they will see concentrated brine as they dry. These should be superduples, K-500, or other Ni based alloy (625).
Rust never sleeps
Thanks for advice all keep it coming,
Any more published information you can provide would be extremely helpful.
M.
http://www.kolsterising.bodycote.com/
That page makes the statement that 'corrosion resistance is unchanged' but it is actually improved in 316 because of the Mo content.
Will titanium nitride hold up to these chloride levels?
M.
Unless you are looking at a metallurgical overlay so that the surface is a significantly different chemistry then you will not achive long term reliability that way.
Your real problem will not be the bold, exposed surfaces. It will be in crevices, at joints, seals and such and on the back side of parts.
I have seen high Cl water pumped with 316 pumps. The seals were continually flushed with clean water and the pumps were fully backflushed with clean water when ever they were shut off. The problem with that is one bad shutdown will destroy the pump. Not high on my list for reliability.
Rust never sleeps
