If loops in Mathcad
If loops in Mathcad
If loops in Mathcad
hey all,
I am having problems in the if statement.
Actually i am using If statement in a model where in the beginning i had to choose what type of coolantside (eg:coolant or air)
So i have to choose various values like mnu,Rho,Cp etc for the coolant or air ).So i got the equation to correlate this values for various temps.
Now the tough thing is when i put a variable saying i choose
Coldside=Coolant or air (starting of the model)
So for me if i select "coolant" down in the model
I want all my coolant related properties to be selected and put in the respective equations.
And also if i select the "Air" it should automatically give the air properties.
I guess i am pretty clear .
Thank u
Vinnu
RE: If loops in Mathcad
You might peruse the Mathsoft Collaboratory.  This subject has come up before.  There have also been some Mathsoft newletter articles about this subject.
http://collab.mathsoft.com/~Mathcad2000
TTFN
Coldside:="Coolant"
mnu:if(Coldside="Coolant",23,45)
mnu=23
If you had a lot of values, it might be easier to use the "if" function to select an index number, then set up a matrix of values.  Use the index number to select the right one.
You might consider using a control component for the initial selection to avoid problems with spelling.
vinnuram,
If you usse a global variable definition for Coldside, then wherever it is in the worksheet, even near the end or in the middle, it will be valid in expressions that precede it.
I always try to put all my inputs at the top of a worksheet, so a user does not have to go hunt for them.
regards,
chichuck
