Hole wizard tapped holes in assembly
I have an assembly that uses 2 components. The one component is a read only file from a library. It is a standard product that we then assemble to a custom product. The components will be welded together but I need tapped holes that will be into both parts to hold other pieces. I'm trying to add tapped holes at the assembly level that will go into both parts. When I add the tapped holes the cosmetic threads are in the custom part (file is not read only) but end in the custom part, the do not pass thru into the standard product (file is read only). I'm assuming my problem is because of the read only but I don't want to change that. Is there any way to get around this? I have tried to just cut extrude a hole and add the cosmetic thread but it will only allow adding it for the thickness of the custom part.
mncad
mncad
RE: Hole wizard tapped holes in assembly
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
SA
mncad
Just between you and I... you are a customer of ours so if you want just send me the files and I will take a look at them and see what i can do to help you out. Just explain what you want to do.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
