2006 SP 0.0 Cut List
Has 2006 SP 0.0 Cut List become a piece of junk or is it just on my computer ?
I just opened Weldment and Drawing, made by someone else (SW 2006) and modified one channel (slightly taller).
Now the Cut List on the dwg goes nuts, the modified item and some other item (which is not even a channel and does not even touch the modified item) have balloon numbers 0 (zero), some empty lines appear in the Cut List (just item number and quantity, nothing in Description, Length, Weight Each).
Deleting and reinserting of New Cut List does NOT help.
Never seen this kind of weird things in 2005.
Any Clues ???
RE: 2006 SP 0.0 Cut List
You have to update the cut-list at the part level. RMB the cut-list and select update, then try it out in the drawing.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
If that doesn't work, try updating the SP.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
