Promotions Vs. wave linking
I was wondering what is the difference between using Promotions and Wave linking for interpart modeling? Also the benifits one way or the other. We currently use Wave linking for all of our interpart modeling. Thanks in advance!!
RE: Promotions Vs. wave linking
I used promotions for adding features to an existing body in the assembly.
Ben Loosli
Sr IS Technologist
L-3 Communications
In a nutshell, what looslib said.....
WAVE is not the same as Geometry links. Even though they appear to allow the same type of linking. They are more like cousins. Geometry links require an assembly or can link geometry within the part. WAVE is primarily used to create a high level dependency and share and build knowledge (datums, general geometry, expressions, rules. Some software packages call this a skeleton. This is not to be shared outside of the company. Then push it over the fence and have a component that is then added to an assembly. WAVE can link to files without requiring an assembly. Now you build your component using that linked geometry.
WAVE can be used to create a customer NX file without giving them the product knowledge, Keeping the internal faces on the body the same, easily updated, They won't see any assembly structure so no errors, the file can contain one or many solids, the solid can be simplified and then WAVE linked.
There should not be any need to remove parameters on any solid. Using WAVE will create an object in another file, there is not any other information in the file that a customer or supplier can extract, especialy if you simplify the model first sort of like a black box.
-Dave
PLM Exchange
http://plmexchange.net
http://groups-beta.google.com/group/NX_CAX/
