API2510 VS API2510A and VS API2218
Some confusion!, I have LPG spherical with automatic deluge spray nozzle on the vessel and fix  water  monitors at 2 position around vessel plus one hydrant. If we refer to above API code, should that vessel to be apllied the fire proofing on the column?.
