ground wire in multi core cable
Are there any tables in the NEC (or equivalent) that specify the minimum size of the ground wire in a multicore cable?
For example, what ground wire size would be used in a #2, 3C, 5kV cable?
Thanks for the help!
RE: ground wire in multi core cable
You must check the cable specs. for the actual size of the ground conductor and then check the code to see if it is adequate for the intended application. You may have to instal an additional ground conductor alongside the cable.
respectfully
