Water storage Tank
Water storage Tank
Hi, im designing a water storage tank, can i use the API-650 to do all the calculations??
RE: Water storage Tank
For municipal/ potable water, normally AWWA D100 would be used, and might be required.
If it's industrial, raw water, waste water, etc., API-650 could be used. Also check out Appendix A as an option.
If it's a small tank, there won't be any savings from using API-650.
API-650 has more details on typical nozzle construction, whereas AWWA D100 has more requirements on ladders and stuff.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Steve Braune
