ASTM A53 Gr.B Stress-Strain Curve
Does anyone have a typical stress-strain curve for ASTM A53 Gr.B carbon steel pipe? If not, something similar?
I would like it for a non-linear FEA model.
RE: ASTM A53 Gr.B Stress-Strain Curve
Why not try the ASTM materials' specification handbook for a start or look up/get in touch with some manufacturers of the material on the net. Those might help
Goodluck.
whiteram.
jt
Wouldn't this be very conservative as the material will keep straining until the stress gets back below the yield stress?
If not, you might want to consider strain hardening effects.
What type of piping configuration are you evaluating which would require a nonlinear analysis?
jt
jt
