How to put another figure above the current one?
I'm trying to get a map with a small map overlaying it. I tried to use subplot. But it does not work, if I draw the big one first, the bigger one will be lost. If I draw the small one first, the big one will cover the smaller one.
Thank you so much for your help!
RE: How to put another figure above the current one?
xnuke
"Do you think you used enough dynamite there, Butch?"
