Displaying yield and failure surfaces
Hi
Is there any way where one can display the yield surfaces and/or failure surface.
RE: Displaying yield and failure surfaces
For elastic stresses above yield, just reset the maximum Von Mises contour limit to yield.
corus
If you use an elastic, plasticmaterial, you can use the Flag variable AC YIELD. Since it's a flag you can set the number of colors to two an use a quiltplot in the contour options.
