A193 B16 and A194 Gr.4
Does anyone know where to find mechanical and physical properties of A193 B16 bolt material and A194 Gr.4 nut material? Thanks a lot.
RE: A193 B16 and A194 Gr.4
h
Table 1 gives composition, Tables 2 & 3 give Mechanical properties in inch-pound and metric, respectively.
Mech props depend on size. For diameters < 2.5 inch, B16 has YS 105 ksi, TS 125 ksi, elongation 18%, max hardness 321 HB or 35 HRC.
[b]ASTM A194/A194M-06, "Standard Specification for Carbon and Alloy Steel Nuts for Bolts for High Pressure or High Temperature Service, or Both."
h
The mech. data for nuts is given as 'Proof Load' on either a threaded mandrel or a hardened steel cone for various thread sizes. E.g., for 1-inch Grade 4 hex nut on threaded mandrel, proof load is 90,900 poundsf and proof stress is 175 ksi. For heavy hex: 106,000 poundsf and proof stress is 150 ksi for heavy hex. Proof loads are most definitely not design loads.
These 2 standards cost $48 & $40. If you might need others, buy the 2006 Annual Book of ASTM Standards vol. 01.01, either book or CD, for $216. http:
