Incorrect Displacement Results
Hi all,
I have described a displacement boundary condition that starts from 0,0 (time(s), disp(mm)) and ends up at 1,-5 using a tabular amplitude. The problem, is at the end of the 1 second dynamic step, the displacement is -5.283 mm not -5.0 mm. Any idea why this is happening or what could be the cause?
Thanks in advance,
Chris
Thanks in advance,
Chris
RE: Incorrect Displacement Results
Chris
Can you please refeer me to that previous posting as I sometimes encounter the same issue
Thank you,
Mark
