1800 RPM otors versus 3600 RPM
Hi guys,
I have a 150HP motor being controlled with a 200 HP VFD. The motor is rated for 3600 RPM. The client now wants to go with a 200 HP motor. Will the VFD need to be increased as well? I know the current ratings of VFD's are based on 4 pole 1800 RPM motors. How does having a 3600 RPM motor affect this?
Thanks for the insight.
RE: 1800 RPM otors versus 3600 RPM
It should not be difficult to find a new 200 HP inverter duty motor that is suitable for use with an existing 200 HP VFD.
http:/
You should determine why the client wants to go to a larger motor and check to see if both the continuous and intermittant capacity of the VFD will be adequate to provide the expected performance.
For example, your motor nameplate says 220 amps. The drive continuous rating at 10% overload for one minute is 230 amps. The drive 5 second rating is 265amps.
The system will be able to operate at 230/220 of motor nameplate continuous, at (230+23)/220 for 10 seconds, and at 265/220 for 5 seconds. All of this assumes the motor stays within its thermal limits as well.
Hope that clears things up.
