worthington pump curve
would anyone have pump curve for a worthington 6LR13 split case pump?
thanks
RE: worthington pump curve
Worthington is now part of the Flowserve Corp.
In my last post, Worthington is part of the Flowserve Pump Group. Your nearest Flowserve Distributor can provide you with a copy of the pump curve.  They will need Impeller diameter and driver speed.
