Thermal Conductivity Test on Small Sample
Need recommendation on labs that can run K value on sample of maximum size of 1.25" dia x .094" thick.
Need test run on instrument which gives a direct K value and which does not require any calculations or projections.
Sample is non-metallic, non-plastic and should have a low K value, likely less than 0.5 W/m-k.
RE: Thermal Conductivity Test on Small Sample
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Yes, I found them while searching over the weekend and called yesterday.
They have given me a quote to do the tests. Their web site is impressive.
Have you used them?
