IEC Cable Rating Explanation (e.g. what does 3.6/6 kV mean?)
What do the following cable ratings mean?
3.6/6 kV
6/10 kV
8.7/15 kV
I believe that they are IEC cable ratings, but what do the two numbers mean? What is the maximum voltage the cable is designed to handle?
Just to give some background, I'm looking for cables suitable for applications at 5 kV, 8 kV and 15 kV. So would I be able to use a cable rated 3.6/6 kV for 5 kV, 6/10 kV for 8 kV and 8.7/15 kV for 15 kV?
Thanks for the help!
3.6/6 kV
6/10 kV
8.7/15 kV
RE: IEC Cable Rating Explanation (e.g. what does 3.6/6 kV mean?)
I don't suffer from insanity. I enjoy it...
Where:
Uo = max phase-to-ground voltage
U = max. Line—to-line-voltage
Um = maximum system voltage.
Here is a typical example of cable rating
‘Designation: 10 kV 15 kV 20 kV 30 kV 50 kV
Uo/U: 6/10 kV 8,7/15 kV 12/20 kV 18/30 kV 36/50 kV
Um 12 kV 17,5 kV 24 kV 36 kV 72,5 kV
