The $ sign and commas in results
Is it possible to format results to look like this: $1,354.50 - I would like to show the results of a calclulation in dollars with commas separating the thousands, millions, etc.  I can't even get commas to work.  I can make a unit "Dollars" and have the result 1354.00Dollars but I stil would like to get the comma delimeters.  Thanks!!
RE: The $ sign and commas in results
You might try searching the Mathsoft user forum:
http://collab.mathsoft.com/~Mathcad2000
Barring that, you could insert an Excel component and display the answer there with the desired formatting.
TTFN
