Calling functions within a function
I am trying to define the variables used in a custom function, but am not having much luck in figuring it out
Example (simplified of course):
Function test(a)
test = Excel.WorksheetFunction.RoundUp(a, 0.1)
End Function
Does anyone know how to add the definition of the selected variable (in this case "a") under the data inputs of the function (when you call the function).
for example... when you call the function "ROUNDUP", it has variables of "Number" and "Num_Digits". For the definition of "Number" it gives it's definition as
"Number is any real number you want rounded up."
Any help is much appreciated!
jproj
Function test(a)
End Function
jproj
RE: Calling functions within a function
Function test(a as Single)
End Function
In its present form :
Function test(a)
the argument 'a' is the 'variant' data type.
If (as ivymike suggests) you are trying to write text to describe each argument in the Function input functionality that comes with Excel (the box which appears to the left of the screen with a separate input area for each arg and explanatory text beneath)...let me see...will get back with something (or maybe nothing) soon.
http://www.j-walk.com/ss/excel/eee/eee009.txt
If you hit the "page down" key six times you should be just below the start of the proceedure...
From what I've heard, this is a difficult little problem. As always, any help is much appreciated.
jproj
1. Open a new workbook
2. Insert a module
3. On the top of the code page of the module enter the lines:
Const Lib = """c:\windows\system\user32.dll"""
Option Base 1
4.Write YOUR function procedures (like the Divide and Multiply examples).
5.Write the Auto_Open and Auto_Close procedures (alternatively you could put these in the Workbook_Open and Workbook_BeforeClose events respectively) - take care to subtitute the relevant parts of the strings you see with those pertaining to your own functions. Note that the arg descriptions are contained in the Auto_open proc.
6. Copy the 'Register' subroutine as is.
The whole idea is that once the functions are registered, they work like the native Excel functions and the arg description will show in the function input dialog box.
For this to work, obviously the workbook containing the above code must be open. To ensure this, try converting this to an add-in and with Tools>addins, add this to the list of Add-ins that automatically load when XL starts. Then the thing will be available in every Excel session.
Hope I was able to be of help...
Good luck!
Thanks for digging it up!
