Fan blades brazing
Fan blades brazing
Fan blades brazing
I have some stainless ID fan blades at a power plant.
We are considering having Conforma-Clad or a similar company braze tungston carbide onto the leading edge.  To perform this process they bake the part at around 2000 degrees F.  This is a twisted and tapered blade and the profile is critical.
Should I be concerned with this process?
Previously we used a spray process to deposit chrome carbide and it worked reasonably well.
Any thoughts?
RE: Fan blades brazing
I would stay with HVOF spray coating.  Heating the entire blade will change its properties and shape.  You may get unpleasant results.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
I'll second EdStainless - we braze around 1500 F and metal movement is always a concern even at these lower temperatures.
tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
