Solving multiple equations using Matlab
Hi all,
I am quite a newbie using Matlab.. I am trying to get Matlab to solve a set of 12 equations with 12 variables using the solve function. I have written something similar to this (I pasted the original at the end):
>>solve=('equa1','equa2',..,'equa12','var1',..,'var12')
Matlabs gives a Warning:Explicit solution could not be found
Would thanks any tips..
Avi
The line:
>> solve('D1^2=h2^2+m^2' , 'D2^2=C1^2+C2^2-2*C1*C2*cos(s1)' , 'L1+L2=C5' , 'sin(b1)=C3/L1*sin(s1+a1)' , 'cos(b3)=(C5^2+D1^2-D2^2)/(2*C5*D1)' , 'sin(b1)=C3/C2*sin(b2+a2)' , 'cos(s2)=(C1^2+h^2-H^2)/(2*C1*h)' , 'sin(b4)=C2/D2*sin(s1)' , 'sin(b5)=L1/D2*sin(b2)' ,'tan(b7)=m/h', 'cos(b6)=(D1^2+C4^2-L2^2)/(2*D1*C4)' , 's2+b4+b5+b6+b7=360', 's1', 's2', 'b1', 'b2', 'b3', 'b4', 'b5', 'b6', 'b7', 'L1', 'L2', 'D2')
Avi
The line:
RE: Solving multiple equations using Matlab
In Maple there is an fsolve command which gives numerical (f for floating) solution. In Matlab maybe it is something like option = numerical?
If you are interested in finding a numerical solution of your system (i.e. an approximation of the solutions of which you can chose the grade of accuracy) check the command fsolve typing help fsolve. This is a numerical solver for systems of nonlinear equations. Remember that for each run of the command you will obtain only one root (whereas your system might admit much many than one solution).
The numerical procedure mught converge towards different solutions depending on the initial guess or it might diverge for a very bad guess.
If you want to find all the solutions I suggest you to implement a cycle in which you randomly chose the initial guess. Since you have a pretty large system of non linear equations I recommend you to do several iterations and memorize the solutions.
