API 620 question ?
API 620 question ?
API 620
paragraph 5.5.4.5
this is the case with one unit force is tensile and the other is compressive.
API says that one has to compute the tensile stress and THEN follow the rest of the procedure
by using for instance figure 5.1 for detemining the N value...etc
My question is :
1/-do we have to include BEFORHAND the joint efficiency E in this N, I mean N define N as =( joint efficiency as per table 5-2) * actual tensile stress / ( allowable tensile stress as per table 5-1)
2/-or do we have to check actual stress to determine N as equal to actual tensile stress / ( allowable tensile stress as per table 5-1)
and then determine N = actual tensile stress / ( allowable tensile stress as per table 5-1)
and check AFTERWARD if N < E otherways use a thicker wall
My interpretation goes for the later : determine N and then check if N < E
paragraph 5.5.4.5
My question is :
RE: API 620 question ?
