flex fuel sensors
flex fuel sensors
Where can I find info on how flex fuel sensors work?
thanks
thanks
RE: flex fuel sensors
http://www.megamanual.com/flexfuel.htm
Might be worth trawling around www using that.
Capacitive fuel level sensors are used extensively on military aircraft.
There must be modern sensor technology for support of 'flexfuel' and E85 vehicles.
This site refering to flexfuel in Brazil is interesting:
http://
Magneti Marelli refer to their method as SFS (Software Flexfuel Sensor). A quick read suggests that exhaust gas oxygen (per the EGO/HEGO/Lambda sensor) is primarily used to set the fueling where varying levels of alcohols are encountered, rather than trying to work out what's in the feed fuel. Maybe they are using wideband/universal EGO sensors.
ht
you can find out more here:
http://www.sae.org/technical/papers/910498
Measurement of refractive index technology is used for new FCS (fuel composition sensors)
