What does d/c mean in component marketplaces?
I have been frequenting several component marketplaces, a great deal of them from the Orient. They consistently have a column header that reads "D/C". Many write values like 99+ or 98+, sometimes ratios, 98/99+. Can anyone explain what D/C and these ratios mean?
Thank you.
-Gary
Thank you.
-Gary
RE: What does d/c mean in component marketplaces?
As in - they haven't tested the product but expect tests to pass 98 components out of 100.
But I await others comments too.
Keith Cress
When buying components through other channels than the usual disribution chain be aware of the following:
- older parts may be difficult to solder
- there might have been some product changes in between and a circuit designed with newer devices might not work with older ones
- you might get old parts containing lead
- for devices difficult to get there might also be counterfait devices ( devices not manufactured by the manufactuerer whose stamp/label they carry) offered on these marketplaces
I'd made the same conclusion about date code being abbreviated D/C. Thank you for confirming that for me. You mentioned several interesting points in regards to older merchandise.
I was looking for an MOS Integrated Circuit. Some have date codes as old as 95+, would you happen to know if these qualify as being too old. And maybe you can help me with this cryptic datecode: 9539+.
Thank you.
If you need parts for series production I wouldn't use parts that old, for repair it should not be a problem.
- do an additional visual ckeck of soldering quality
- look for PCNs issued in between
- check if the parts are leadfree if required
- you also may ask the former manufacturer on his point of view, even if the device is obsolte he will usually be able to test it or to analyse samples it. But he may charge you for that.
