Data Aire vs Liebert
Can anyone offer some comparison notes on Data Aire vs Liebert?
RE: Data Aire vs Liebert
MONEY
I'm not a real engineer, but I play one on T.V.
 A.J. Gest, York Int./JCI
yes, money is part of it but if your use is mission critical go with the liebert, they are: more reliable and have better turn around on parts when needed, but yes they cost more.
I havent had the chance to compare apples to apples yet, but I am actually getting a higher quote on the Data Aire unit.  About $1800.  When you mention cost, does that apply to parts, service, repair, & maintenance also, or would that be about the same?  I know this can vary, but in general.
The Data Aire does have some discharge ducting, custom made, which I think would at most compensate for the $1800, but I dont see it reversing the comparison.
Anything?
Thanks for all the input
I posted "money" more tongue in cheek. I've always considered Liebert on the high end but I strongly feel you are getting a quality product. Data Aire I've always though was middle of the road. A lot depends on what tyoe of unit you are looking at.
Not too experienced in this end of things, but I have heard of and seen Lieberts much more than of Data Aire. That doesn't necessarily mean anything.
Ed
www.engineerboards.com
Liebert offers infrared humidifiers, but Data Aire does not.  I prefer the infrared over the steam generator canisters, which need to be replaced often.  The infrared is low maintenance when using DI water.  A new lamp every couple years is all.
---KenRad
In out area, Liebert provides excellent customer service regardless of the size of the project. They help us out on projects that uses one 2 ton mini-mate just as thouroughly as a project that uses 20 mini-mates.
We always specify Liebert unless the owner wants another manufacturer.
I know I didnt answer your question but just wanted to add my 2 cents.
any input is great.  if everyone give me 2cents, i get a dollar ...
