General Motors - DCS compliance problem
HI,
We are one of the Vendor to GM supplier.
I have problem while running DCS compliance.
DCS compliance is prerequisite as per GM standard.
I have used UGNX2 with same GM file checker(DCS compliance). It is working fine. But when i installed UG NX3. It is giving the below error message,
***** MISCELLANEOUS NX AND UFUNC ENVIRONMENT ERRORS *****
ERROR NO. 1102: Could not validate the site_optional_refset file.
Reference set name: MODEL
Check that the site_optional_file is readable and correctly formatted.
To fix this error i have tried several optons but i could not solve it.
Please give me some solution to resolve this issue?
Some members in this forum might be overcome the above mentioned problem.
Please help me out. I need to resolve this issue ASAP.
Thanks in advance.
Thanks in advance.
RE: General Motors - DCS compliance problem
Welcome other people suggestions.
Please post your reply.
Thanks in advance.
Are you using Teamcenter?
What have you already tried?
Did you get the latest version of GMPDL for NX3?
1. There is an actual file that lists the names of site optional reference sets and the file was over-written or not copy/pasted during the toolkit upgrade (from NX2 to NX3).
2. The environment variable for site_optional_refset file has not been defined since upgrading to the NX3 toolkit.
I'd suggest combing through the installation directory of the toolkit and looking for a particular file for situation #1 above and/or looking at gmlaunch.bat, gmlaunch.dat or any other toolkit specific files that contain default settings.
If you can live without the MODEL reference set, then just delete it.
If not and you still can't find the problem, call the GM helpdesk for support. Their phone number is listed on gmsupplypower.com.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Now with that said, the error you are recieving means that the file that lists site defined reference sets is either read only or it does not exist. Have your site admin check the permissions on the file.
Also, make sure you have the GMPDL that was updated for NX3.
Error No. 1102: Could not validate the reference set.
Reference set name: XXXX
Check that the site_optional_file is readable and correctly formatted. Where ‘XXX’ is the reference set name.
Cause: Could not open the site_optional_file to validate named refset.
Solution: Validate that the site_optional_file in $FILE_CHECK_SITE_REFS is readable and correctly formatted. Where FILE_CHECK_SITE_REFS is an environment variable. Refer to File Checker Requirements Document.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
I want to thank all the people who posted your valuable feedback.
Special thanks to Tim flater.
When we had purchased the GM tool bit, we have missed it.
I couldn't find it from the GM tool bit.
I appreciate it.
Madhan kumar
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Meantime, team asked me to send file checker requirements documents which i dont have it.
I have requested you to send it to me.Please, i appreciate it.
Madhan
When you say you are at customer site, do you mean GM? I can tell you who at GM can help you with your problem and possibly provide you with the documentation.
I believe he's in the states and the people that are actually having the issue are in India...Madhan is sort of the "go between" if you will.
Madhan,
The documentation is included with the toolkit, if it's downloaded from GTAC (UG's support site). If you install the toolkit, you will need to navigate to the install directory then browse to [toolkit install path]\gmpdl3b13\docs. There you will find all the documentation for the toolkit (that's included with the download). To find out what specific File Checker errors are, refer to the file named fc_users_guide.html.
If you have a specific issue where you need support and the toolkit guides are of no help, you can call or email GM's support folks at:
GEES Service Desk 1-888-238-1119, Monday through Friday, 7am-5pm, EDT or send an email to geescallcenter@eds.com.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
The help desk is level 1 general support. If you call them, ultimately you will be forwarded to someone else. The group that handles this type of problem for GM is called the Engineering Design Assistance Group. As I said before, I worked for 15 years at GM and worked as a Teamcenter and NX support person and trainer, among other responsibilities. If you are at the GM tech center, I can tell you who to contact regarding this issue for both help and documentation.
As for the problem with the file being in India, it's no problem as the support folks here have access to the India database.
Of course, this all means little if you are not visiting GM, but I am assuming since you are using the GMPDL that your client is GM. If that is the case there should not be a problem contacting the responsible folks at GM.
Rightnow,I am not at GM site. We are one of the supplier to GM supplier and doing some Modeling and detailing work for GM supplier. We have end up this problem.
Based on your feedback,I have send your replies to india. This is what i received from india,
Suggestion 1:
REPLY FROM INDIA: This solution is available in DCS file checker help and we have read thro it already. In the same solution you can find “please refer File checker Requirements Document" and we have given a request for this doc in note # 2.
So try to get "File checker Requirements Document" from customer.
2) Suggestion 2:
A) There is an actual file that lists the names of site optional reference sets and the file was over-written or not copy/pasted during the toolkit upgrade (from NX2 to NX3).
REPLY FROM INDIA: We have newly installed GM tool kit for NX3 and we have only NX3 in our machine and our installation is not an up gradation.
B) The environment variable for site_optional_refset file has not been defined since upgrading to the NX3 toolkit.
REPLY FROM INDIA: We have already set the Environment variable site_optional_refset.
We think "site_optional_file" is referring to a file but we do not have any file by that name. so please confirm with the customer and try to get this file.
“FILE_CHECK_SITE_REFS=%GMPDL_DATA_DIR%\filechk\site_optional_refsets” This is the declaration set in the Gmlaunch.dat file in our installation. Please talk to customer and ask them any file is stored within this declared folder. We have this empty at our end.
Could please send me some feedback?
What is happening is that the toolkit is looking for a file that defines ADDITIONAL reference sets that your company wants to use. YOU DON'T HAVE TO USE THEM!!! Either this site_optional_refsets file doesn't exist or it has the wrong permissions because you're using a reference set that DOES NOT BELONG with a GM part (based on GM's data requirements). If your company doesn't NEED additional reference sets, then the environment variable in gmlaunch.dat needs to be commented out with an asterisk (*) so the toolkit will stop looking for it. You will need to restart NX for the change to take effect. Commenting out the environment variable is NOT going to fix the problem in your part though...you need to also DELETE the reference set that doesn't belong!
I don't have any further solutions. I feel we have isolated the problem and now you need to figure out how to remove the reference set that is causing this whole problem. It's an OPTION (the MODEL reference set) and obviously your users do not know how to set up the toolkit so that user defined reference sets can be used. Since that's the case, then DON'T USE THEM!
There isn't a user guide that is going to solve this problem or tell you how to fix it, no matter how many times you ask.
One other option is to call GTAC and send them the part and have them remove the reference set (MODEL) that is causing the problem and then see if the file passes the file checker.
You can also try exporting the part to a NEW NX part and see if that helps at all.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
You stated that everything was fine in NX2. Well, the MODEL reference set existed in NX2 and you were set up to pass files with the MODEL reference set. This means that you did not update properly when you went to NX3.
You need to get ahold of GTAC and get the "site_optional_file". File checker will not work properly without it.
Also, deleting the MODEL reference set will not work because it is automatically created by NX3 when you have geometry. That is why GM revised file-checker to allow it.
I wouldn't mess with the gmlaunch.dat file. Instead you need to install everything EXACTLY as GM has installed.
Your IT guys should have some contact at GM that can help them.
I never understood why we have to "fit" UG to the toolkit (after we've already installed NX)...the toolkit should "fit" to where NX is already installed, not force you to install to C:\eng_apps\, which is NOT the default path NX3 wants to install to....perfectly logical, huh?
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Messing with the gmlaunch file is only asking for trouble. It is designed to give you the exact environment you need to meet their standards.
Believe me, I didn't always agree with them but ultimatly they are the ones paying and like it or not they are the customer.
With all that said, the best way to solve the problem that started this thread is to make absolutly sure that averything is installed per GM environment.
The team has solved this issue and end up with our problem.
Reply from the team,
"The error got eliminated when we deleted the reference set "MODEL" , But reference set "MODEL" is generated automatically in a UG file by default, so when ever we save the model this reference set is generated again, and the error appears again when we run the file checker. We are trying to find out whether "MODEL" reference can be eliminated. Refer the attached image for the screen shot of the reference set"
Could please suggest how to delete MODEL from refernce set permanenetly from Ref. set?
Ben Loosli
Sr IS Technologist
L-3 Communications
Deleting the reference set may work in this instance but what other problems are going to occur because of the improper installation.
I can agree to disagree with fgbrender about the editing of the gmlaunch.dat file...it's just a bunch of environment settings that point to varying locations. Not a big deal for experienced users to understand or learn how it works. On top of that, GM supplies a gmlaunch.dat-ref file that can be renamed to gmlaunch.dat should a user really screw something up in their edited gmlaunch.dat file...that's a BIG reason why it's no longer a big deal to change the .dat file...besides, if you DON'T edit the gmlaunch.dat file AND you've installed NX BEFORE even looking at anything to do with the tookit (as I'm sure a LOT of people have done in the past), you're either going to have to edit the gmlauch.dat file or completely reinstall NX (to C:\eng_apps) to even get the toolkit to run. But hey, that's not the topic of the thread and we're all allowed to have our own opinions. Not a big deal.
kumarm2,
Your people can keep asking for us to fix the problem, but until the toolkit software is installed and configured correctly, I'm afraid they're going to keep having this issue. In case you don't understand, the toolkit install is either missing a file (whatever defines site_optional_refset) or the file is the correct location but has the wrong permissions, name, format, or the toolkit is not pointing to the correct location of the site_optional_refset file. The only way your NX part file is going to pass the current file checker is if you get this site_optional_refset variable issue fixed.
I really don't understand what's so bad about calling GEES helpdesk either....they NORMALLY take your call, assign it to a technical person and then they call you back. Granted, it can take a few days for some major issues, but I've never been in a situation where they don't call back and offer some sort of help. I'd call them again if I were you....they SHOULD be able to assign someone to help confirm the NX and toolkit install is correct back in India if the difference in time zones can be alleviated somehow.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
I have resolved the issue. Thanks for your valuable information.
I appreciate for you help.
Madhan
Thanks.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Guess I didn't give much thought to the install directory. Maybe editing the gmlaunch file ain't such a bad idea, by an experienced user, of course ;)
As for the helpdesk, I wasn't suggesting that he not call, I was only suggesting that if he was on site at GM it might be easier to go to the support people directly. Unfortunatly not an option.
GM works in such a customized environment, it has to be difficult for suppliers who have other clients as well.
I'm also curiouse as to how the problem was resolved...
