laptop usb port
laptop usb port
laptop usb port
Hi everyboady. I have a laptop DELL inspiron 1300. I want to use it for linking with PLC but it have`nt a serial port. it only have USB port. can anybody recommend me any model or brand?
RE: laptop usb port
Me too. Only, you have to use exotic com numbers. Like com4: and com5:
Gunnar Englund
www.gke.org
RE: laptop usb port
These USB-serial converters absolutely will not work with A-B's 1747-PIC, so don't waste your time or money trying. Thankfully they have released a USB replacement in the form of the 1747-UIC which is reasonably priced and works reliably, two notable improvements over the 1747-PIC!
  I don't suffer from insanity. I enjoy it...
RE: laptop usb port
But, is it an AB PLC the OP is using?
I don't see why an USB/232 adapter that works with all systems I have tested (drives, PLCs, development systems, measurement interfaces) shouldn't work in his case - which we do not know much about.
Gunnar Englund
www.gke.org
RE: laptop usb port
Yes, very good question! Which PLC?
A-B's problem stems from the 1747-PIC being quite an old product. It draws power from the port, and is quite power-hungry by the modern standards. The power requirement is met by the original PC/AT serial port spec from years ago, but  more modern computers are able to supply less power from their  serial ports. Laptops are probably the worst in this respect, but my PIC doesn't work reliably with newer desktops either. A-B's solution, as you might guess, is 'buy different hardware'.
I wonder if it is practical to incorporate a small external power source to run the PIC?
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/310D1DD7CF69924785256AFB005D8953
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/2B0EF50431B6637C85256AFB005565A8
RE: laptop usb port
Power hungry. Yes, that's a problem. I guess that a powered USB hub could help in some cases.
Gunnar Englund
www.gke.org
RE: laptop usb port
In 2005 i purchased an Acer Travelmate 2355XC laptop.  i was so exited to own my own laptop that i did not notice it did not have a serial port. In the manual it said that you could have one fitted if you required it.  I asked around and was advised that you could use a USB to RS232 adaptor.  I purchased a Meccer USB to 232 adaptor from a computer store and it works great. I have used it on Moeller Easy PLC,s and Omron.  I have not been able to get it to work with a Telemechanique plc though.
RE: laptop usb port
I had some problems when developing a microcontroller based measuring systems. Whenever I connected one of these in the serial port of the device, the readings went crazy. However, the grounding and shielding weren't very good... which might have something to do with it. :\
