Animation in AutoCAD
I am working on some assembly drawings for our production floor, and I was also going to try and integrate some of the 3D drawings into our company website. I want to animate one of the door slabs to open when you enter the site. Is this possible to do through CAD or does it require another program?
Thanks for the help,
GMWindow
GMWindow
RE: Animation in AutoCAD
There is also a program called "swift 3D" that can make flash animations.
If you want to keep it simple, you can just do a gif animation with a freeware program.
John
GMWindow
http:
If you go the following site and look under "graphics and imaging", they have alot of freeware animation and CAD related programs. There is also an animation program called openFX that you may want to check into. I think it may handle CAD files direct.
http://www.freewr.com/
Hope this helps.
John
I just thought I would pass this along in case it can help anyone.
John
