model far away
model far away
model far away
When I focus (by pressing the f button) on my model, the model appears far away. I have to zoom in to see my model.
This is making it impossible to work on my model. How can I fix this.
RE: model far away
Whenever I zoom in on the model and press down on the scroll bar to change my viewpoint, the model disappears. If I focus again (by pressing f) the position of the model is different from what it was before I zoomed in.
It appears that by attempting to change my viewpoint I am moving the model.
RE: model far away
It sounds like you might have a component that is not properly mated.  It could be flying out in space at some great distance, and when you try to focus (Zoom to Fit) the view is being drawn back to include this part.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: model far away
Or, stop using the F key to do this.  (Yeah, I know that's not a fix, but will certainly make work "possible" until finding the problem.)  I think MadMango's suggestion sounds right.  Is that the problem?
I use my scroll wheel to zoom and arrow keys to rotate, pan, etc. and I'm very fast with that.  I also use saved and standard views.  If you have a nice mouse, you can press down your scroll wheel (as a button) and rotate the model, then zoom in where you need to be with the un-pressed scroll wheel.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
RE: model far away
If its a part, you might have a sketch or something out in space. I have seen this happen often, you can edit each sketch or click on the sketches to see if anything highlights (like a point) that might be causing you your zoom issue.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: model far away
We have been seeing this with tapped holes having a very large diameter phantom circle.  The fix seems to be changing the size of the tapped circle to a different size and then changing it back.
Eric
RE: model far away
Yeah, I've had Eric's problem, too.  His fix works.
Jeff Mowry
RE: model far away
Actually the fix for that is to edit the HW hole remove the cosmetic thread and re-add it. But if that was his problem it would be seen easily.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: model far away
It could also be a large plane or extended axis. Turn on all the options under the View menu. You may also have to Show all planes, axes, sketches, etc in the FM tree.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: model far away
I have seen this with derived parts. It wants to see something that is linked within the assy
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
