Can not select lines of a drawing view
I have a problem from time to time where I can not select lines on drawings for dimensions etc.
I thought at first that it was because of hidden parts in the drawing view blocking the lines. It was not.
Then thought it may have been a drawing view overlapping the problem view. It was not.
I am using SW2006 sp4.1
Has anyone else had this?
James
NZ
James
NZ
RE: Can not select lines of a drawing view
Try moving your drawing off the sheet.
Worked for me.
Dan
Vintage Millworks
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I got it to work by opening the model and then opening the tree and then rebuilding and randomly selecting things as they were not highlighting in here either. Then went back to the drawing and it worked.
This happens quite offen tho.
We have talked to our service provider here in New Zealand and they told us it will be in the next service pack.
I don't use them much and they wonder why:)
This is still a problem and hope someone finds a fix.
James.
PS: I'm moving to Cork, Ireland, if anybody knows of any companys requiring an experienced solidworks operater.
I can give you the name of the SolidWorks reseller in Ireland if you like, they may be able to give you information.
Let me know if you want it.
bandh
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Thanks Scott, I have even tried machine gunning ctrl-Q.
Sometimes zooming right out can work. But there seems to be nothing that fixes it completly.
Thanks to all
James
http:/
Cough, cough, when is that next service pack comming out?
Tune the performance / image quality back a bit. This has worked for me in the past
www.solidsolutions.ie
Bandh
