change origin
change origin
Is it possible to change the origin of the part after the part has been created?
I was wondering if i can make all parts to have the same origin in an assembly.
thank you
thank you
RE: change origin
This way, each of the parts is fixed to the same origin.
You can use this technique to properly position components with any plane you'd like.
