Corrosion Rate AISI 1026
How is the corrosion rate of AISI 1026 effected by acid concentration, specifically comparing corrosion rate in a 15% HCl enviroment to a 28% HCl environment?
RE: Corrosion Rate AISI 1026
The corrosion rate is so high as to be meaningless.
